Dropdown list: click several times on the same line
Hi all,
I have a drop-down list with various actions. For example resetting a counter. This counter must often be reset but I cannot click twice on the same line of the drop-down list. (Today I have to select another action to be able to click again on my "counter reset" line)
Is there a way to tell the dropdown that I would like to click as many times as I want on the same line?
You can do kind of reset mechanism to clear last choice after a little delay.
See I placed first option as dummy and if you send same data, it will be chosen but you then filter that out as no action should follow.
[{"id":"b6da561d9b14e38a","type":"ui_dropdown","z":"09deee63c1b960f7","name":"","label":"","tooltip":"","place":"Select action","group":"08ac9b242ae51e8c","order":11,"width":0,"height":0,"passthru":false,"multiple":false,"options":[{"label":"Select action","value":-1,"type":"num"},{"label":"Action one","value":1,"type":"num"},{"label":"Action two","value":2,"type":"num"},{"label":"Action three","value":3,"type":"num"}],"payload":"","topic":"topic","topicType":"msg","className":"","x":380,"y":100,"wires":[["7c7631f7ac46e4b3"]]},{"id":"737447316fbbd0b8","type":"debug","z":"09deee63c1b960f7","name":"action","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":770,"y":100,"wires":[]},{"id":"7c7631f7ac46e4b3","type":"switch","z":"09deee63c1b960f7","name":"","property":"payload","propertyType":"msg","rules":[{"t":"neq","v":"-1","vt":"num"}],"checkall":"true","repair":false,"outputs":1,"x":570,"y":100,"wires":[["628c83b629bf0d2f","737447316fbbd0b8"]]},{"id":"4e3cf42d291060b2","type":"link in","z":"09deee63c1b960f7","name":"reset dropdown","links":["2e0921a373d3faab"],"x":285,"y":160,"wires":[["b6da561d9b14e38a"]]},{"id":"2e0921a373d3faab","type":"link out","z":"09deee63c1b960f7","name":"dropdown reset","mode":"link","links":["4e3cf42d291060b2"],"x":815,"y":160,"wires":[]},{"id":"628c83b629bf0d2f","type":"trigger","z":"09deee63c1b960f7","name":"wait and reset","op1":"","op2":"-1","op1type":"nul","op2type":"num","duration":"1","extend":false,"overrideDelay":false,"units":"s","reset":"","bytopic":"all","topic":"topic","outputs":1,"x":660,"y":160,"wires":[["2e0921a373d3faab"]]},{"id":"08ac9b242ae51e8c","type":"ui_group","name":"Default","tab":"2acb95821445c8af","order":1,"disp":true,"width":"6","collapse":false,"className":""},{"id":"2acb95821445c8af","type":"ui_tab","name":"Home","icon":"dashboard","disabled":false,"hidden":false}]
And if the delay is not good choice for reset, you can make any logic to figure out when to send reset to dropdown.
great it works!
It led me to another idea: as it's a dynamic drop-down list, you just have to reload the list as soon as the device that receives the action, sends the ACK of good reception. The last command is deleted!
