hello everyone!
I have I file.json, when I import it into my nodered and node SQL doesn't work (econnrefused). I try to use the same user and passwork with person who exported this file but it's still doesn't work. So can anyone please give me instruction in this case?
Thanks everyone!
Which database server (MS SQL, MySQL, SQLite ...) and which SQL node are you using (node-red-contrib-something probably)?
[Edit] Looking again I can see that it is MySQL, so which node are you using? Also have you installed MySql Server on the PC running node red?
