Edit red.js file
hello my friends I'm editing a function file red.js button deploy I saw that it has this function but when doing the build it returns to the original state someone has already made this modification.
packages/node_modules/@node-red/editor-client/public/red/red.js
I'm editing the same in this place, but when I build it, it comes back to the original file.
* options:
* type: "default" - Button with drop-down options - no further customisation available
* type: "simple" - Button without dropdown. Customisations:
* label: the text to display - default: "Deploy"
* icon : the icon to use. Null removes the icon. default: "red/images/deploy-full-o.svg"
function init(options) {
options = options || {};
var type = options.type || "default";
Hi @jhonnsec
Welcome to this forum!
packages/node_modules/@node-red/editor-client/public/red/red.js is the file created when building the Node-RED system. Thus it's the wrong place to do any modifications.
The source of the snipplet you're looking for is located in packages/node_modules/@node-red/editor-client/src/js/ui/deploy.js. If you modify this file, your changes will end up in .../red/red.js.
