Editing the dashboard login interface
Hi, I was wondering if anyone knows if it is possible to easily change the dashboard login user interface (image below). The node red editor has a proper login page with a image, but the dashboard does not. Would like to at a minimum remove the "your connection to this site is not private", but adding a logo similar to that of the editor login page would be great.
Dashboard Login
This message indicates that you're not using HTTPS, I believe it's a good thing to leave that there for the benefit of the users... Or, really, you should upgrade to HTTPS :wink:.
As mentioned above.
This is not Node RED, this is your browser, advising you're not using a secure connection to Node RED.
See here to enable HTTPS in Node RED
https://nodered.org/docs/user-guide/runtime/securing-node-red
As far as changing the logo on the login page, see here.
If you wish to go beyond just updating the logo.
https://nodered.org/docs/api/ui/themes/
EDIT
Just realised this is specific to Dashboard, but I'll leave it here anyway. :sweat_smile:
The login prompt you are referring to, cannot be customised, as its part of the browser you're using.
Thanks tve
Thanks Marcus
