Hi All,
I was using the Node Red 1.3.0-beta.1 version & I was seeing encoding feature in MQTT nodes where I was able to set encoding as UTF-8.
But the same feature is not available in latest Node Red v1.3.4.
Can anyone help me how to set encoding as UTF-8 in MQTT nodes in latest version.
Thanks,
Suraj
which MQTT node(s)? "MQTT in" "MQTT Out" "MQTT config"?
can you do a screenshot explaining where you seen this / where it is missing from?
are you referring to the MQTT V5 option "Payload Format Indicator"?
Yes I was referring about the format indicator.
I was seeing this format option in v1.3.0-beta.1 but not able to see in the latest node red as shown in above image.
When MQTT v5 integration was finalised, this was removed (for reasons I cannot answer).
however...
- are you connected to a V5 type MQTT broker & are you using the V5 "Payload Format Indicator" in your applications?
- Is this actually causing you an issue?
- Are you validating the payload & issuing a PUBACK, PUBREC, or DISCONNECT with Reason Code of 0x99 (Payload format invalid) as described in section 4.13.
