Error connecting to Database (MSSQL)
"ConnectionError: Login failed for user ''." is the error i get when i try to connect to the database can anyone help
Hi, welcome to the forum.
When posting a question it helps to include certain info that may prove useful to someone helping you...
  • What node-js version are you using (node -v)
  • What node-red version are you running
  • where is node-red running (on a PI, Windows, Mac etc)
Can you also please answer...
  • Which SQL node are you using (node-red-contrib-mssql-plus is recommended / most actively supported, most features)
  • What SQL version are you attempting to connect to?
  • Have you enabled SQL Login or are you trying to use integrated login.
Hi
Im using the below versions
Node.js v16.13.2.
Node-RED version: v2.1.4
Windows_NT 10.0.19042 x64 LE
I used the node-red-contrib-mssql node
Microsoft SQL SERVER 17
Integrated Login
That node is abandoned. uninstall it and try the node-red-contrib-mssql-plus version.
Also, i am unsure about integrated login (SQL logins definitely work)
