I am not able to connect to the Azure SQL database in node-red. I am using Azure SQL node but it throws an error : Error: {"message":"Login failed for user 'rbb_admin@iot-energy'.","code":"ELOGIN"}
Note: I am running node-red on raspberry pi, in case that is of an issue.
I am not sure what seems to be the problem, as I am using the same credentials using MYSQL workbench (windows) to connect to the database and it works.
Any guidance will be of great help.
