So i tried to connect my node red and SQL. But it can't login with the current username and password. I checked and it is the correct username and password, i tried to make another username and it's still failed to login. Is there any step on settings to "enable" connect node red and sql? or I make some mistake when I created the username on SQL?
I am using node.js v20.9.0
node-red version 3.1.5
I used the node-red-contrib-mssql-plus node
Microsoft SQL SERVER 19
Ok, so instances are typically not run on the default port number, you will need to find what was port number was dynamically assigned by SQL server to your instance and enter that port number on the sql config node.
