OK, so this code is AI generated so take with a generous pinch of salt.
However, on import, it generates a node marked as invalid but with no way to fix the issue! It is the Wait node that has the error. Nothing is shown in the log.
I've never seen this before and I don't think it should ever happen, importing a node with no way to fix an error.
Incidentally, I can manually re-create the delay node with exactly the same settings with no error.
"id": "tab_downloads",
"type": "tab",
"label": "Downloads Manager",
"disabled": false
"id": "watch",
"type": "watch",
"z": "tab_downloads",
"name": "Watch Downloads",
"files": "C:\\Users\\YOUR_USERNAME\\Downloads",
"recursive": false,
"x": 160,
"y": 80,
"filter"
"id": "filter",
"type": "function",
"name": "Ignore temp files",
"func": "const path = require('path');\n\nconst file = msg.payload;\nconst ext = path.extname(file).toLowerCase();\n\nif (ext === '.crdownload' || ext === '.tmp') {\n return null;\n}\n\nreturn msg;",
"outputs": 1,
"x": 390,
"y": 80,
"delay"
"id": "delay",
"type": "delay",
"name": "Wait 5 seconds",
"pauseType": "delay",
"timeout": "5",
"timeoutUnits": "seconds",
"x": 610,
"y": 80,
"moveImage"
"id": "moveImage",
"type": "function",
"name": "Move images",
"func": "const fs = require('fs');\nconst path = require('path');\n\nconst file = msg.payload;\nconst ext = path.extname(file).toLowerCase();\n\nconst images = [\n'.jpg','.jpeg','.png','.gif','.bmp','.webp','.tif','.tiff','.svg','.heic','.avif'\n];\n\nif (!images.includes(ext)) {\n return null;\n}\n\nconst dir = path.dirname(file);\nconst targetDir = path.join(dir,'images');\n\nif (!fs.existsSync(targetDir)) {\n fs.mkdirSync(targetDir,{recursive:true});\n}\n\nconst dest = path.join(targetDir,path.basename(file));\n\ntry {\n fs.renameSync(file,dest);\n node.status({fill:'green',shape:'dot',text:path.basename(file)});\n}\ncatch(err){\n node.error(err,msg);\n}\n\nreturn null;",
"outputs": 0,
"x": 820,
"y": 80,
"id": "injectHourly",
"type": "inject",
"name": "Hourly",
"props": [],
"repeat": "3600",
"once": true,
"onceDelay": "5",
"x": 140,
"y": 220,
"archiveOld"
"id": "archiveOld",
"type": "function",
"name": "Archive files >6 months",
"func": "const fs = require('fs');\nconst path = require('path');\n\nconst downloadDir='C:\\\\Users\\\\YOUR_USERNAME\\\\Downloads';\nconst archiveDir=path.join(downloadDir,'archive');\n\nif(!fs.existsSync(archiveDir))\n fs.mkdirSync(archiveDir,{recursive:true});\n\nconst cutoff=Date.now()-183*24*60*60*1000;\n\nfor(const item of fs.readdirSync(downloadDir)){\n\n if(item==='archive' || item==='images')\n continue;\n\n const full=path.join(downloadDir,item);\n\n let stat;\n\n try{\n stat=fs.statSync(full);\n }\n catch(e){\n continue;\n }\n\n if(stat.isDirectory())\n continue;\n\n if(stat.mtimeMs<cutoff){\n try{\n fs.renameSync(full,path.join(archiveDir,item));\n }\n catch(err){\n node.warn(err.message);\n }\n }\n}\n\nreturn null;",
"outputs": 0,
"x": 410,
"y": 220,
