Nodes disappear when importing subflows
Hi All,
I'm using nodered 1.2.9 and imported quite a big flow (tab) which is a reengineered variant of an already existing flow (tab) so they have pretty much in common. After the import -no matter if I choose to replace everything what's possible or just import everything as a copy- certain nodes disappeared. Surprisingly enough not only subflows but function nodes as well.
Before import:
After import:
Best regards,
r0ller
PS.: Choosing 'Import Copy' into a new tab works though fine as it used to.
Very strange. Can you check the browser log for any error messages?
Is there a flow you can share with me that reliably recreates the issue?
Sorry, but I don't get what you mean by browser log. Just the console log after the import? Concerning the flow to share to be able to recreate the issue I'll need to find a minimal example. These tabs are huge :slight_smile: Today I'm pretty busy but will post it here in a few days.
Depending on which browser you are using, there will be a JavaScript console somewhere. For example, with Chrome, it is under: View -> Developer -> JavaScript console
Ok, that I know of course :slight_smile: I'll post it here if I see there anything. However, as I started nodered in foreground I can see some stuff in the terminal like:
10 Feb 11:01:37 - [error] TypeError: util.promisify(...).call(...).then(...).otherwise is not a function
(node:21920) UnhandledPromiseRejectionWarning: TypeError [ERR_INVALID_ARG_TYPE]: The "path" argument must be of type string or an instance of Buffer or URL. Received type function ([Function])
at Object.lstat (fs.js:892:10)
at String. (/home/llencses/tungsram/node_modules/graceful-fs/polyfills.js:298:16)
at String.Object.defineProperty.value (/home/llencses/tungsram/node_modules/universalify/index.js:5:67)
at internal/util.js:297:30
at new Promise ()
at String. (internal/util.js:296:12)
at Object.getLibraryEntry (/home/llencses/tungsram/node_modules/node-red-contrib-yaml-storage/localfilesystem_yaml.js:373:41)
at Object.getLibraryEntry (/usr/local/lib/node_modules/node-red/node_modules/@node-red/runtime/lib/storage/index.js:148:34)
at Object.getEntry (/usr/local/lib/node_modules/node-red/node_modules/@node-red/runtime/lib/library/local.js:26:20)
at Object.getEntry (/usr/local/lib/node_modules/node-red/node_modules/@node-red/runtime/lib/library/index.js:49:35)
(node:21920) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag --unhandled-rejections=strict (see Command-line options | Node.js v15.8.0 Documentation). (rejection id: 16)
It may even turn out that it has something to do with the yaml storage...
Sorry, strangely enough the error above was copied from the terminal where that nodered instance ran from which I exported the tab.
Yes, it looks like there's an issue for the YAML storage plugin to fix, but that won't be related to what the editor does when you import a flow.
So would still like to know if the browser's console has any errors in it.
Actually.. having said it isn't related, I see the stack trace is on 'getLibraryEntry'.
I had assumed you were copy/pasting the flow - but are you actually importing it from the library? If so, it could well be related.
So, this is what I see in the console:
JQMIGRATE: Migrate is installed, version 3.3.0 vendor.js:4:711
XML Parsing Error: syntax error
Location: http://10.109.234.193:1880/settings?_=1612952990205
Line Number 1, Column 1: settings:1:1
Password fields present on an insecure (http://) page. This is a security risk that allows user login credentials to be stolen. 10.109.234.193:1880
Node-RED: 1.2.9 red.min.js:16:17435
Versions red.min.js:16:17471
Projects disabled red.min.js:16:8936
Source map error: Error: request failed with status 404
Resource URL: http://10.109.234.193:1880/vendor/vendor.js
Source Map URL: purify.min.js.map
Unexpected value translate(NaN,NaN) parsing transform attribute. red.min.js:16:309590
Unexpected value undefined parsing width attribute. red.min.js:16:309835
Unexpected value undefined parsing height attribute. red.min.js:16:309879
Unexpected value translate(38,NaN) parsing transform attribute. red.min.js:16:311324
Unexpected value translate(NaN,NaN) parsing transform attribute. red.min.js:16:313265
Unexpected value NaN parsing y attribute. vendor.js:35:6328
Unexpected value undefined parsing height attribute. red.min.js:16:313697
Unexpected value translate(NaN, -2) parsing transform attribute. red.min.js:16:313909
Unexpected value translate(NaN, -2) parsing transform attribute. red.min.js:16:314053
Unexpected value translate(NaN,0) parsing transform attribute. red.min.js:16:310895
Unexpected value translate(NaN,NaN) parsing transform attribute. red.min.js:16:311034
Unexpected value translate(NaN,2) parsing transform attribute. red.min.js:16:314567
Unexpected value translate(NaN,NaN) parsing transform attribute. 2 red.min.js:16:313265
Forgot to answer your question: yes, I'm importing the flow not copying/pasting.
Sorry for the lag, I've just had some time to check the issue with yaml storage disabled in both the source and the target project and unfortunately the result is the same. I also tried it with a minimal example (even with yaml storage enabled) but then I could not reproduce the issue. So I guess it has to do something with the size.
