Hi, I have issues to run node-red locally using docker-compose up. My colleagues are using Mac and Linux and can run the remote repo locally. I am using Windows, and am getting this error:
Attaching to nodered-1
nodered-1 | Error loading settings file: /data/settings.js
nodered-1 exited with code 1```
That happens when I install project packages using npm.
It works fine when I install them using yarn, but we need to use npm, as there are some other issues with yarn.
As a setup for the project using npm works for colleagues on Mac and Linux I guess there are some inconsistencies with Windows, or access, any ideas?
Rename your settings.js file to settings.bak and restart your docker container
From the Node-red Manual :
When Node-RED starts, it looks for a file called settings.js in your Node-RED user directory, ~/.node-red. If it does not find one there, it will copy in a default settings file to that directory and use it.
This would create a new default settings.js just as a test to eliminate the possibility of it being a misconfiguration in the file
