Error message from tf-coco-ssd node
From time to time I get this error message in the debug log. Normally it runs fine but then suddenly I can see one or two of those. Using version 1.05 on a RPi4 (used "npm rebuild @tensorflow/tfjs-node --build-from-source" to make it work after installation via palette i NR)
I also reported it in the "right place" I hope
I can report I also get the same error occasionaly as @krambriw with exactly the same setup.
i.e. v1.0.5 running on a RPi4B with Buster.
I think the node is fine, instead I do suspect the image data is corrupted when this happens. Issue is closed for now. Check out my comment on github
