I'm using red-node with Docker, but in situations where there is a wrong configuration when deploying, docker enters a loop restarting.
Is there a way in case of an error to stop the flow?
Can you show us an example of what you mean? I don't see how Docker can get into a loop since Docker is just the container.
You can pass in an environment variable at startup to start in safe mode which won't deploy the flow - so you should then be able to edit it and fix whatever is broken. see startup section Running under Docker : Node-RED
