How start node-red without any flows running? Have a module that is generating uncaught exception, and it keeps crashing node-red. The issue is module has a bad parameter setting, but since the flow keeps running when node-red runs... caught in an endless loop!
you can start node red in SAFE-Mode. This will start node-red but not start the flows
depending on your setup it can be as easy as
node-red --safe
please read the documentation
Ah... I tried node-red --no-flows... but that did not work, completely forgot about --safe. Thx.
Just for reference for those using docker (I had this problem today ) set the environment variable
NODE_RED_ENABLE_SAFE_MODE=true
(And change it back to false for normal ops)
