I need to read the data on my ESP32. data that I send from a local NODE-RED, to my NODE RED in IBM CLOUD, which data reaches the server and NODE RED CLOUD, now he wants to know about a program that helps me read this data in IDE ARDUINO, to be able to perform an action such as turning a led on or off
#include <WiFi.h>
#include <WiFiClient.h>
#include <PubSubClient.h>
//-------- your wifi -----------
const char* ssid = "CELERITY_MONTALVAN";
const char* password = "1722510060B.";
#define ORG "5hjcib"
#define DEVICE_TYPE "raspberry1"
#define DEVICE_ID "comunicacioniot"
#define TOKEN "123456789Bf"
//-------- Bluemix information to build up MQTT message -------
char server[] = ORG ".messaging.internetofthings.ibmcloud.com";
// this part I need to know how to subscribe to topics that IBM WATSON sends me
char pubTopic[] = "iot-2/evt/status/fmt/json";
char subTopic[] = "iot-2/cmd/test/fmt/String";
char authMethod[] = "use-token-auth";
char token[] = TOKEN;
char clientId[] = "d:" ORG ":" DEVICE_TYPE ":" DEVICE_ID;
WiFiClient wifiClient;
PubSubClient client(server, 1883, NULL, wifiClient);
const char ledpin3 = 4;
void receivedCallback(char* pubTopic, byte* payload, unsigned int length) {
Serial.print("Message received: ");
Serial.println (pubTopic);
Serial.print("payload: ");
for (int i = 0; i < length; i++) {
Serial.print((char)payload[i]);
Serial.println();
/* we got '1' -> on */
if ((char)payload[0] == '1') {
digitalWrite(ledpin3, HIGH);
} else {
/* we got '0' -> on */
digitalWrite(ledpin3, LOW);
void setup() {
Serial.begin(115200);
Serial.println();
pinMode(ledpin3, OUTPUT);
Serial.print("Connecting to ");
Serial.print(ssid);
WiFi.begin(ssid, password);
while (WiFi.status() != WL_CONNECTED) {
delay(500);
Serial.print(".");
Serial.println("");
Serial.print("WiFi connected, IP address: ");
Serial.println(WiFi.localIP());
if (!client.connected()) {
Serial.print("Reconnecting client to ");
Serial.println(server);
while (!client.connect(clientId, authMethod, token)) {
Serial.print(".");
delay(500);
client.setCallback(receivedCallback);
if (client.subscribe(subTopic)) {
Serial.println("subscribe to cmd OK");
} else {
Serial.println("subscribe to cmd FAILED");
Serial.println("Bluemix connected");
void loop() {
client.loop();
if (client.publish(pubTopic, (char*) payload.c_str())) {
Serial.println("Publish ok");
} else {
Serial.println("Publish failed");
this is a program on which I am basing myself to be able to connect to the IBM CLOUD server, but the part of reading what the server sends me is missing to perform an action
