ESP32-C3-Super-Mini not connecting to WiFi channel > 6
Just found out by 2-hrs of frustration that the ESP32-C3-Super-Mini won't connect to any WiFi channels higher than channel 6. I'm using it to send T/H/P readings via MQTT to Node-RED.
sat_ESP32
I suspect the reason is the physical size of the ceramic antenna labelled C3 in the photo above.
There do seem to be a number of people reporting wi-fi issues -
https://www.reddit.com/r/esp32/comments/1cu96tz/esp32_doesnt_like_wifi_channel_11/
Quick update
I did a range check with the ESP32-C3-Super-Mini by placing it in my greenhouse at the end of my garden. Line-of-sight distance from the node to the nearest access point was 25m (82 feet).
It is sat next to another PCB fitted with an ESP32-S2-Mini - with a "squiddly" antenna.
