I'm trying to install Base64 and Fileinject node, but I have this kind of error running.
I have node v18.1.0 and npm 8.0.0 on windows.
Node-red just updated to version 2.1
Any help?
Do you have a need for the latest version of node.js or could you go back to v16?
the error is referring to msal-node - not sure which node is requiring that - but it isn't the base64 one.
Hi!
No need to stick on that. Do I have to go back?
Hi!
Is there anyway I can sort which is the node that is interfering?
thanks in advance for the answer
Yes, go back to node-js 16 or remove the node in question (assuming you dont need it).
Out of interest...
From inside your node-red folder/directory, what does running npm list @azure/msal-node show?
I suspect it is an MSSQL node.
