Filebased installation of Nodes
Hi everybody,
are there any plans for a possibility to install new Nodes from a file which was created via npm pack?
Kind Regards,
Dennis
from the command line ?
No sorry, actually I meant by using an upload button or something like that inside the UI of Node-RED. Maybe located at the "Manage palette" section.
Kind Regares
Sorry for bringing this topic up again: are there any plans for a filebased installation of Nodes via UI?
Kind Regards
Dennis
You could do it yourself if you really need it. Any node red package placed in node-red\nodes folder will get loaded upon node red start up.
So create a flow with an endpoint that lets you upload a pack, then use the zip node to unpack it into the nodes folder.
