Trying to deploy node-red-contrib-stripe and I am getting a MODULE_NOT_FOUND error.
I add the stripe node and place the stripe test key in the Edit Stripe Node Config
(stripe-config) but I keep getting the error.
It appears that this field does not remain populated after I deploy.
I figured I'd try to setup the Projects feature of NR this time around, and I suspect that might be interfering? I could be wrong.
I've tried to remove, uninstall the stripe nodes, and re-enter the config keys but to no avail.
