Flowforge device omit node red code?
I would like to know if the flowforge agent omits the node-red code.
I'll explain the situation:
I have a system developed in NODE-RED, this system will run on remote servers. But I would like the IT team to have access to this server.
But I would not like to have access to the NODE-RED code (system source code). As a matter of intellectual property.
In the case in question, is the flow-forgeagent omitting this executed code?
Remembering that in my case I need the execution to be on an offline server (It cannot depend on the internet on the server).
@knolleary @Steve-Mcl
The Device Agent pulls down the Node-RED flow configuration from the platform and stores it on the local disk of the device. It then runs Node-RED using that saved copy of the flows. This is how it is able to run Node-RED even if the internet connection back to the platform is unavailable.
Anyone with command-line access to the device will have access to the flow configuration.
