Flows not triggering - Home Assistant
I have a flow created and deployed for the past few months and all has been working fine up to some recent updates to Node-Red in Home Assistant.
Now nothing will trigger, is this a known issue or is there something that i need to change since the recent updates of HA etc.
Flow: Friends of Hue Switch-Light state check-Turn light on/off
Add-on version: 14.5.0
You are running the latest version of this add-on.
System: Home Assistant OS 10.5 (armv7 / raspberrypi3)
Home Assistant Core: 2023.10.0
Home Assistant Supervisor: 2023.10.0
Hi @deano - welcome to the forums
I am afraid this will likely be something on the HA side (most here do not use HA, and instead use Node RED bare-metal) or even the node author for Hue Magic - you will need to ask one of those if something has broken with recent updates they have published.
The plugin for HA - has been getting warnings with a change made to JSONata processing - but that is for the author of the HA nodes to address.
