Following update wake on lan flow no longer works
Hello all
I am hosting HA as a vm in proxmox. And i am trying to wol a HTPC on the same network
Following updates from HA, and Node red, my wake on lan flow to turn on the htpc via wol wait 15 seconds then turn on my amp plug.
The wol node does not turn on the HTPC
The following is a printout of my flow to turn on my media environment
> 6/22/2024, 8:52:17 AM[node: Time Start](http://192.168.1.128:8123/api/hassio_ingress/4p4e278-ENCBuzyhIY8i8uNwNFiSFtkRsgBaMgfSl78/#)msg.payload : number
> 1719039130905
> 6/22/2024, 8:52:17 AMStart HTPCsent data : msg :
> object
> domain: "wake_on_lan"
> service: "send_magic_packet"
> data: object
> mac: "10:7B:44:50:33:80"
> broadcast_address: "192.168.1.119"
> 6/22/2024, 8:52:17 AM[node: Turn on HTPC](http://192.168.1.128:8123/api/hassio_ingress/4p4e278-ENCBuzyhIY8i8uNwNFiSFtkRsgBaMgfSl78/#)msg.payload : number
> 1719039130905
> 6/22/2024, 8:52:32 AM[node: Wait 15 seconds](http://192.168.1.128:8123/api/hassio_ingress/4p4e278-ENCBuzyhIY8i8uNwNFiSFtkRsgBaMgfSl78/#)msg.payload : number
> 1719039130905
> 6/22/2024, 8:52:32 AM[node: Turn On Amp](http://192.168.1.128:8123/api/hassio_ingress/4p4e278-ENCBuzyhIY8i8uNwNFiSFtkRsgBaMgfSl78/#)msg : Object
> object
> _msgid: "16051aab63e9189c"
> payload: 1719039130905
I checked my settings on my HTPC and wol is enabled in the bios
the network adapter has wol enabled.
yet no joy
Thank you in advance for any help provided
Blockquote
Screenshot 2024-06-22 at 11.13.16
:grimacing:
Honestly, you're better off speaking to the HA community - most here are not HA users
Thank you just the same for responding however i would have expected if my NR config was correct
The problem is that you are running Node-RED as a plugin to HA, not natively. If you have the same problem when running natively, I'm sure there will be more people able to help.
We often come across issues introduced by how HA interacts with Node-RED unfortunately but because most of us don't use HA, we are unable to help.
thank you for this reply. i did raise this with HA,
ONCE AGAIN THANL YOU
