Using node-red-contrib-alexa-remote2-applestrudel (5.0.55) in a Home Assistant Node-Red add-on.
Is there a way to list all routines exposed by Alexa to Node Red?
Use the Alexa Other node, select GET. and under WHAT? select Automation Routines. Inject to a debug node and paste the resulting data to a JSON editor to analyse.....
Thanks for the tip. I tried this but get an "Error: Invalid sequence node"
Can you look at my flow and tell me where I went wrong?
[{"id":"19d9acde0f56e031","type":"inject","z":"5d1b0398.99236c","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":120,"y":200,"wires":[["c8bfa98b532c239e"]]},{"id":"5c2cb414f1f4dfff","type":"debug","z":"5d1b0398.99236c","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":690,"y":200,"wires":},{"id":"c8bfa98b532c239e","type":"function","z":"5d1b0398.99236c","name":"function 1","func":"msg.payload = {\n option: "get",\n value: {\n what: "automationRoutines"\n }\n};\nreturn msg;\n","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":,"x":300,"y":200,"wires":[["e134f97ba382dbac"]]},{"id":"e134f97ba382dbac","type":"alexa-remote-routine","z":"5d1b0398.99236c","name":"","account":"4627f780.84a6a8","routineNode":{"type":"custom","payload":{"type":"msg","value":"payload"}},"x":480,"y":200,"wires":[["5c2cb414f1f4dfff"]]},{"id":"4627f780.84a6a8","type":"alexa-remote-account","name":"","authMethod":"proxy","proxyOwnIp":"192.168.1.57","proxyPort":"3456","cookieFile":"alexa.txt","refreshInterval":"1","alexaServiceHost":"pitangui.amazon.com","amazonPage":"amazon.com","acceptLanguage":"en-US","userAgent":"","autoInit":"off"},{"id":"767cea8a456df408","type":"global-config","env":,"modules":{"node-red-contrib-alexa-remote2-applestrudel":"5.0.55"}}]
A quick look shows an error for importing, but in any case there´s initially little to show in a flow here -
Summary
"id": "def7600210803eeb",
"type": "alexa-remote-other",
"z": "21d84dbb515216e9",
"account": "c8738129.d902c",
"config": {
"option": "get",
"value": {
"what": "automationRoutines"
"x": 490,
"y": 560,
"0abbf3c1275e6f45"
"id": "0abbf3c1275e6f45",
"type": "debug",
"name": "debug 2742",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "payload",
"targetType": "msg",
"statusVal": "",
"statusType": "auto",
"x": 890,
"y": 560,
"id": "4dfc8442c13e9286",
"type": "inject",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "",
"payload": "",
"payloadType": "date",
"x": 195,
"y": 560,
"def7600210803eeb"
"id": "2036e74dbc3ac86a",
"type": "comment",
"name": "Identify Alexa Routines (JSON)",
"info": "",
"x": 215,
"y": 505,
"id": "c8738129.d902c",
"type": "alexa-remote-account",
"name": "alexa remote 2",
"authMethod": "proxy",
"proxyOwnIp": "192.168.0.85",
"proxyPort": "3456",
"cookieFile": "/data/context/alexa.json",
"refreshInterval": "0",
"alexaServiceHost": "alexa.amazon.es",
"pushDispatchHost": "",
"amazonPage": "amazon.es",
"acceptLanguage": "es-ES",
"onKeywordInLanguage": "",
"userAgent": "",
"usePushConnection": "on",
"autoInit": "on"
"id": "486f598734bd6e58",
"type": "global-config",
"env": [],
"modules": {
"node-red-contrib-alexa-remote2-applestrudel": "5.0.55"
Once identified use the Alexa Routine node to execute -
