I am using a sensor to send data data to Azure, and want to show the data in real time by using mqtt node to send it to io.adafruit.com , the problem is .. I can do that from the sensor direct by connecting the mqtt node to the sensor, but if I use the mqtt node after the Azure iot hub to get the data from the hub, it shows "message sent" and does not show the value of the sensor. Is there any way to do that?
Why not send it before as you have working in the top flow ?
just wanted to know if there is a way to get the data after azure hub! I can get data easily before it.
