Getting error ampq when installation
I am trying to install amqp node for nodered.
I am using this command in my windows command prompt: npm install -g node-red-contrib-amqp
I am getting this error:
2023-03-30T15:46:35.179Z Install : node-red-contrib-amqp-ack 1.1.2
2023-03-30T15:46:56.736Z npm install --no-audit --no-update-notifier --no-fund --save --save-prefix=~ --production --engine-strict node-red-contrib-amqp-ack@1.1.2
2023-03-30T15:46:57.218Z [err] npm
2023-03-30T15:46:57.218Z [err] WARN config production Use --omit=dev instead.
2023-03-30T15:46:59.828Z [err] npm ERR!
2023-03-30T15:46:59.829Z [err] code EBADENGINE
2023-03-30T15:46:59.830Z [err] npm ERR! engine Unsupported engine
2023-03-30T15:46:59.830Z [err] engine Not compatible with your version of node/npm: amqplib@0.4.2
2023-03-30T15:46:59.830Z [err] npm ERR! notsup
2023-03-30T15:46:59.830Z [err] Not compatible with your version of node/npm: amqplib@0.4.2
2023-03-30T15:46:59.830Z [err] npm ERR! notsup Required: {"node":">=0.8 <6 || ^6"}
2023-03-30T15:46:59.830Z [err] npm ERR! notsup Actual: {"npm":"9.5.0","node":"v18.15.0"}
2023-03-30T15:46:59.832Z [err]
2023-03-30T15:46:59.832Z [err] npm ERR! A complete log of this run can be found in:
2023-03-30T15:46:59.832Z [err] npm ERR! /tmp/data/.npm/_logs/2023-03-30T15_46_57_192Z-debug-0.log
2023-03-30T15:46:59.840Z rc=1
Can anyone please suggest what to do?
Thanks in advance
See Unsupported engine for amqplib@0.4.2 · Issue #36 · abreits/node-red-contrib-amqp · GitHub which is an unnadressed issue more than two years old. The node is no longer supported so you will probably have to fix it or find an alternative way of doing what you want.
ok thansk ,
There is any other option to connect rabbitmq in nodered?
Have you checked out all the options in Library - Node-RED?
