Go e wallbox over mqtt and node red
Hi there, I try to connect my go e wallbox to my node red logic. I get all information of the box but cannot send any command such as "alw", "amp". I also tried to connect over "ids". Box receives and answers with success but does not switch anything as far as I see. Does anyone have a simular problem or can say how this thing works (firmware is 59.4). Thank you very much.[
        "id": "cb59ca7e.67d638",
        "type": "mqtt in",
        "z": "6b3071d362553b25",
        "topic": "go-eCharger/409549/#",
        "qos": "2",
        "datatype": "auto-detect",
        "broker": "0d3c22a06edf6381",
        "nl": false,
        "rap": false,
        "inputs": 0,
        "x": 160,
        "y": 100,
                "c726eedd60c09a18",
                "6bc8a32c03cb6241",
                "a0a9fbc8bc0c8eab"
        "id": "84b2520e.ad482",
        "type": "ui_text",
        "group": "d265234bf702ff52",
        "order": 7,
        "width": 5,
        "height": 4,
        "name": "Ladestatus",
        "label": "",
        "format": "<font size = 4>{{msg.payload}}",
        "layout": "row-center",
        "className": "",
        "style": false,
        "font": "",
        "fontSize": "",
        "color": "#000000",
        "x": 890,
        "y": 160,
        "id": "3ac85715.04c588",
        "type": "function",
        "func": "switch (msg.payload) {\n    case 1:\n    msg.payload = 'Ladestation bereit, kein Fahrzeug';\n    return msg;\n    \n    case 2:\n    msg.payload = 'Fahrzeug lädt';\n    return msg;\n    \n    case 3:\n    msg.payload = 'Warte auf Fahrzeug';\n    return msg;\n    \n    case 4:\n    msg.payload = 'Ladung beendet, Fahrzeug noch verbunden';\n    return msg;\n}\n",
        "outputs": 1,
        "timeout": "",
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 670,
        "y": 160,
                "84b2520e.ad482"
        "id": "9bf7777e.d47fb8",
        "type": "ui_gauge",
        "name": "Ladestrom",
        "order": 8,
        "width": 5,
        "height": 4,
        "gtype": "gage",
        "title": "<font size=1>Ladestrom",
        "label": "A",
        "format": "{{value}}",
        "min": 0,
        "max": "32",
        "colors": [
            "#ca3838",
            "#ca3838",
            "#ca3838"
        "seg1": "",
        "seg2": "",
        "diff": false,
        "className": "",
        "x": 890,
        "y": 100,
        "id": "c726eedd60c09a18",
        "type": "switch",
        "property": "topic",
        "propertyType": "msg",
        "rules": [
                "t": "eq",
                "v": "go-eCharger/409549/amp",
                "vt": "str"
        "checkall": "true",
        "repair": false,
        "outputs": 1,
        "x": 450,
        "y": 100,
                "9bf7777e.d47fb8"
        "id": "6bc8a32c03cb6241",
        "type": "switch",
        "rules": [
                "t": "eq",
                "v": "go-eCharger/409549/car",
                "vt": "str"
        "checkall": "true",
        "repair": false,
        "outputs": 1,
        "x": 450,
        "y": 160,
                "3ac85715.04c588"
        "id": "a0a9fbc8bc0c8eab",
        "type": "switch",
        "rules": [
                "t": "eq",
                "v": "go-eCharger/409549/alw",
                "vt": "str"
        "checkall": "true",
        "repair": false,
        "outputs": 1,
        "x": 450,
        "y": 220,
                "fa2323694950847d"
        "id": "11da7a5865d9d8d2",
        "type": "mqtt out",
        "topic": "go-eCharger/409549/ids/set",
        "qos": "",
        "retain": "",
        "respTopic": "",
        "contentType": "",
        "userProps": "",
        "correl": "",
        "expiry": "",
        "x": 940,
        "y": 220,
        "id": "6a7c8d900e3ce3ca",
        "type": "mqtt out",
        "qos": "",
        "retain": "",
        "respTopic": "",
        "contentType": "",
        "userProps": "",
        "correl": "",
        "expiry": "",
        "x": 940,
        "y": 280,
        "id": "332cdeeb5819a0b6",
        "type": "function",
        "name": "mapping",
        "func": "let map = {\n    1: {\"amp\":6,  \"frc\":2},\n    2: {\"amp\":7,  \"frc\":2},\n    3: {\"amp\":8,  \"frc\":2},\n    4: {\"amp\":10, \"frc\":2},\n    5: {\"amp\":24, \"frc\":2}\n};\n\n// Nur 1 Permit‑Zustand, 0 Stop‑Zustand\nlet permit = (msg.payload === 0) ? 0 : 1;   // 0 = Stop, alles andere = Start\n\nmsg.payload = {\n    \"amp\": map[msg.payload]?.amp || 6,   // Standardstrom 6 A\n    \"frc\": permit\n};\n\nreturn msg;",
        "outputs": 1,
        "timeout": 0,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 460,
        "y": 280,
                "6a7c8d900e3ce3ca"
        "id": "7c65240d36981b34",
        "type": "ui_dropdown",
        "label": "Phasenanzahl",
        "tooltip": "Phasenanzahl einstellen",
        "place": "1 -3 Phasen",
        "order": 18,
        "width": 5,
        "height": 4,
        "passthru": true,
        "multiple": false,
        "options": [
                "label": "1 Phase",
                "value": 1,
                "type": "num"
                "label": "2 Phasen",
                "value": 2,
                "type": "num"
                "label": "3 Phasen",
                "value": 3,
                "type": "num"
        "payload": "",
        "topic": "",
        "topicType": "str",
        "className": "",
        "x": 140,
        "y": 360,
                "11646c39cac27077"
        "id": "11646c39cac27077",
        "type": "mqtt out",
        "topic": "go-eCharger/409549/set/pha",
        "qos": "",
        "retain": "",
        "respTopic": "",
        "contentType": "",
        "userProps": "",
        "correl": "",
        "expiry": "",
        "x": 940,
        "y": 360,
        "id": "67f74a1f3c5a6bbe",
        "label": "Strom einstellen",
        "tooltip": "Strom",
        "place": "6 - 32 A",
        "order": 17,
        "width": 5,
        "height": 4,
        "passthru": true,
        "multiple": false,
        "options": [
                "label": "6A",
                "value": 1,
                "type": "num"
                "label": "7A",
                "value": 2,
                "type": "num"
                "label": "8A",
                "value": 3,
                "type": "num"
                "label": "10A",
                "value": 4,
                "type": "num"
                "label": "24A",
                "value": 5,
                "type": "num"
                "label": "aus",
                "value": "0",
                "type": "str"
        "payload": "",
        "topic": "",
        "topicType": "str",
        "className": "",
        "x": 140,
        "y": 280,
                "332cdeeb5819a0b6"
        "id": "fa2323694950847d",
        "type": "ui_switch",
        "label": "",
        "tooltip": "Wallbox an- und ausschalten",
        "order": 4,
        "width": 2,
        "height": 1,
        "passthru": false,
        "decouple": "true",
        "topic": "",
        "topicType": "str",
        "style": "",
        "onvalue": "{\"alw\":1}",
        "onvalueType": "json",
        "onicon": "fa-power-off bigIcon",
        "oncolor": "green",
        "offvalue": "{\"alw\":0}",
        "offvalueType": "json",
        "officon": "fa-power-off bigIcon",
        "offcolor": "red",
        "animate": true,
        "className": "",
        "x": 650,
        "y": 220,
                "11da7a5865d9d8d2"
        "id": "612057c09e9b58a8",
        "type": "ui_template",
        "name": "icon style fĂĽr switch",
        "order": 1,
        "width": 0,
        "height": 0,
        "format": "<style>\n    .bigIcon{\n        font-size:3em;\n        transition: 1s;\n    }\n    .bigIcon.red{\n        color:red;\n    }\n    \n</style>",
        "storeOutMessages": true,
        "fwdInMessages": true,
        "resendOnRefresh": false,
        "templateScope": "local",
        "className": "",
        "x": 150,
        "y": 440,
        "id": "624f23dfe81fa777",
        "name": "Icon Wallbox",
        "order": 2,
        "width": 1,
        "height": 1,
        "format": "<i class=\"fa fa-plug\" style=\"color:red; font-size:20px;\">",
        "className": "",
        "x": 130,
        "y": 480,
        "id": "2dc0efb8af67f553",
        "type": "mqtt out",
        "topic": "go-eCharger/409549/frc",
        "qos": "",
        "retain": "",
        "respTopic": "",
        "contentType": "",
        "userProps": "",
        "correl": "",
        "expiry": "",
        "x": 930,
        "y": 560,
        "id": "66c7e6dc59fc39b6",
        "type": "inject",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "0",
        "payloadType": "num",
        "x": 130,
        "y": 560,
                "2dc0efb8af67f553"
        "id": "536c991cfae43518",
        "type": "inject",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "1",
        "x": 130,
        "y": 600,
                "2dc0efb8af67f553"
        "id": "c2a53e3b79206b93",
        "type": "inject",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "2",
        "x": 130,
        "y": 640,
                "2dc0efb8af67f553"
        "id": "ff7f2a5590da9643",
        "type": "inject",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "payloadType": "date",
        "x": 200,
        "y": 220,
        "id": "0d3c22a06edf6381",
        "type": "mqtt-broker",
        "broker": "192.168.178.123",
        "port": "1883",
        "clientid": "",
        "autoConnect": true,
        "usetls": false,
        "protocolVersion": "3",
        "keepalive": "60",
        "cleansession": true,
        "autoUnsubscribe": true,
        "birthTopic": "",
        "birthQos": "0",
        "birthPayload": "",
        "birthMsg": {},
        "closeTopic": "",
        "closeQos": "0",
        "closePayload": "",
        "closeMsg": {},
        "willTopic": "",
        "willQos": "0",
        "willPayload": "",
        "willMsg": {},
        "userProps": "",
        "sessionExpiry": ""
        "id": "d265234bf702ff52",
        "type": "ui_group",
        "name": "GOe",
        "tab": "6dd6fbb7.f2a4b4",
        "order": 1,
        "disp": true,
        "width": "16",
        "collapse": false,
        "className": ""
        "id": "6dd6fbb7.f2a4b4",
        "type": "ui_tab",
        "name": "GO-e",
        "icon": "dashboard",
        "order": 1,
        "disabled": false,
        "hidden": false
Did you try searching the internet for a solution? You should go to this link:
Though it looks like you will need to use HomeAssistant.
Do you mean that it is working correctly over mqtt except for sending commands?
If so then can you point us to the docs for sending the commands via mqtt? Also create a very simple flow using just an inject node to set the data and the mqtt node, which demonstrates the problem, and post that here.
Hi, it is as always i suggest! Reading through the API at go-eCharger-API-v2/mqtt-de.md at main · goecharger/go-eCharger-API-v2 · GitHub made me try this (see flow) and what shall I say, it worked. I always tried the wrong parameter "alw" which means "allow loading". I also tried writing on the parameter "ids" and sending the command as a json. Both doesn't work, allthough documented. I will build me logik around that, an post the result when its ready. Thanks for your support.
        "type": "mqtt out",
        "topic": "go-eCharger/409549/frc/set",
        "qos": "",
        "retain": "",
        "respTopic": "",
        "contentType": "",
        "userProps": "",
        "correl": "",
        "expiry": "",
        "x": 940,
        "y": 560,
        "type": "inject",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "0",
        "x": 130,
        "y": 560,
                "2dc0efb8af67f553"
        "type": "inject",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "1",
        "x": 130,
        "y": 600,
                "2dc0efb8af67f553"
        "type": "inject",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "2",
        "x": 130,
        "y": 640,
                "2dc0efb8af67f553"
        "port": "1883",
        "clientid": "",
        "usetls": false,
        "keepalive": "60",
        "birthTopic": "",
        "birthQos": "0",
        "birthPayload": "",
        "birthMsg": {},
        "closeTopic": "",
        "closeQos": "0",
        "closePayload": "",
        "closeMsg": {},
        "willTopic": "",
        "willQos": "0",
        "willPayload": "",
        "willMsg": {},
        "userProps": "",
        "sessionExpiry": ""
