using the flow "Goodwe SEMS portal Solar panel data to Node-RED" to get data from my GOODWE panels.
Updated the flow to include my account and and password and the psid (which I got from the portal by logging in successfully)
Get a "Connection Refused" error from the 'Request Token' node.
See this thread: Goodwe SEMS portal Solar panel data to Node-RED · GitHub
And try your code in the swagger api: http://www.goodwe-power.com:82/swagger/ui/index#!/CommonController/CommonController_CrossLogin_0
GoodWe migrated to Version 2 of the SEMS portal about 18 months ago and changed a lot of the APIs - i never bothered migrating my old code as i talk to my inverters directly through Modbus.
You should be able to do this with a standard HTTPS call and not worry about the custom nodes - it is not too hard to work out what each of the fields returned are once you break them out as an object and send them to the debug window
Craig
