Goto local ip address and open page
is there a way i can redirect to a local ip address for example http://192.168.0.152 and open the page for viewing from node red. the address displays my external camera.
I am sure there is a way but not sure which command to use.
i do not want to display the image in node-red just open a separate window at that ip address.
Do you mean a hyperlink that opens http://192.168.0.152 ? on the dashboard?
Can you explain further what you are trying to achieve?
Perhaps include a screenshot with annotations if you are struggling to explain?
hi @Steve-Mcl ,
I use uibuilder and want to include a switch that does exactly that, opens http://192.168.0.152 to allow a quick view of the outside camera ,
and thanks for your quick reply :slight_smile:
is it also possible from within node-red as well ?
what is a "switch"? Do you mean a button <button ... /> or a hyperlink <a ... />?
A hyperlink is as simple as adding <a href="http://192.168.0.152" target="_blank">my camera</a> in your HTML (not really a node-red question, more a general HTML question TBH) - unless i am still misunderstanding your question?
You mean in the node-red editor? Not really no. (though you could hack the src)
hi @Steve-Mcl
yes can see how do do the hyperlink in uibuilder now but as you say not in the editor, was just asking in case i was missing the obvious thanks for your time.
uibuilder already includes a link to the defined page. Open the settings panel in the Editor and the link is right there.
But otherwise, the editor is not a Dashboard. Instead create a simple root page somewhere and use it as a menu. You can also use uibuilder's details link which shows all of the uibuilder url's you've defined along with a load of other details.
Hmm, would an index node be useful? Something that returns a list of defined Node-RED endpoints?
thanks for that @TotallyInformation , i know i would find it useful :wink:
