Group Node - Horizontal Layout
I notice that the Group UI node places content in a vertical layout regardless of the Group width.
I want to display something like a Toolbar at the top of my layout. It has a size of 1x20.
I want the tool buttons to layout horizontally across the width.
How can I do this?
Thanks!
Hi @tcontrada
the widgets will be laid out horizontally if they are sized properly.
By default, a widget is set to fill the horizontal space of the group its in. But you can change that to a fixed width via its edit dialog.
So if you have a 20x1 (width then height) group, then if you make each button 1x1 then you will get 20 of them in a row.
Thanks, worked perfectly!
Is it possible to define in units the specific vertical position of a widget within a group?
Yes if you use the layout editor. (You can do it manually by adding spacers but that's a pain). The layout button should be on the tab row in the dashboard sidebar
Thanks, I meant the horizontal position but it works with the spacer option in the layout editor.
I have changed the horizontal size of my group to 5 units but how could I change the unit size (by default of 48 pixels) so that my 1x1 buttons are larger?
On the dashboard sidebar - site tab
