Group of tab to popup
hi
possible to integrate a group of tab to popup msgbox like notification node ?
if note any other way
Not sure what you mean by this... you want a popup with tabs in ? Or you want multiple tabs to control a popup ? If the former - well you can inject html and javascript into the popup - but that could get complicated fairly quickly unless you have a lightweight way of generating tabs in html.
ex: show login widget in popup dialog
you could adapt this...
hi thanks, I am don't known you can add more input in the popup
but I use the login form for example only
what if you use table widget or you want to integrate any widget ! it does not work rite
AFAIK, dashboard widgets cannot be "popped up"
If you want to pop something up, youre probably gonna have to implement the HTML/JS yourself.
ok thanks
