"Grouping nodes" - I'm not getting it
This is more me catching up with things and while looking for something else I saw this.
58 seconds in
I have 1.1.2
But I can't see how to create the group.
Sorry, but the video isn't showing me how this is done.
My take is that I just drag/select the nodes and that window opens. But it doesn't and I don't see how to get it to.
After selecting nodes, press Ctrl-Shift-G to create the group, or select the Create Group option in the main menu.
Thanks.
Indulge me: was that declared in the clip I mentioned?
Because if it is, I need my ears testing.
(I'm just wanting to be sure. I seem to be making a lot of mistakes just now.)
Yes, thanks Paul. But in the clip I posted (at the top) 58 seconds in you group select nodes and can colour then group, and so on.
The key presses seem to have not been mentioned - unless my ears are failing - and so I was stuck at that point.
Well you have two options;
  1. Use the key presses as per Nick
    or
  2. Use the menu, as per my video
There are key presses for most of the node-RED commands, but yes, I get your point.
(Ok, I'll bite....)
Which video?
and that key sequence didn't exist prior to 1.1.x
Click on the image 4 posts up.
Oh! Sorry..... I really am not with it.
I just saw that as a picture.
Sincerest apologies.
Andrew in times of uncertainty, you can always bring up the action list menu (ctrl+shift+p) and start typing. This can be a very quick way of doing many things in node red including group actions, disabling selected nodes, pretty much anything you can do from a menu or click action is in there + more.
Thanks. I really used to be a keyboard person - using key inputs - but alas slowly I am becoming a mouse person.
I shall have to sit down one day and look at all those key short cuts.
ctrl+shift+p is a good one to learn
Nice.
But now I'm stumped on how you get the Search part open.
It can't be "search flows"....... So.....
Same as before. Ctrl+f
Ah! Ok. Just that usually Ctl f brings up the browser's "search on this page". This would seem then that NR is intercepting the keys and using its own search.
Speaking of ctrl-f is there a way from the keyboard to get to the browser search? I find that in discourse forums, the first time does a forum search, but a second gives you the browser search. In node red, I haven’t been able to find a way to do it. Both types do search can be useful, but I wish I didn’t,have go to browser menu with mouse when I need browser search.
Press F3 - works in chrome on windows.
A Google search would almost certainly found that, but thanks for the quick reply.
In Firefox as well.
