hi I cant deployment node-red
2023-07-10 11:28:33.132: 10 Jul 10:28:33 - [info]
Welcome to Node-RED
2023-07-10 11:28:33.133: 10 Jul 10:28:33 - [info] Node-RED version: v3.0.2
2023-07-10 11:28:33.133: 10 Jul 10:28:33 - [info] Node.js version: v16.20.0
2023-07-10 11:28:33.133: 10 Jul 10:28:33 - [info] Linux 4.14.255-311-248.529.amzn2.x86_64 x64 LE
Listening ...
this my file
package.json
"name": "node_heuo",
"version": "0.0.7",
"engines": {
"node": "16.x"
"dependencies": {
"child_process": "latest",
"express": "latest",
"feedparser": "latest",
"moment": "latest",
"nano": "latest",
"node-red": "latest",
"node-red-contrib-actionflows": "latest",
"node-red-contrib-aedes": "latest",
"node-red-contrib-cron-plus": "latest",
"node-red-contrib-cx-mqtt-one": "latest",
"node-red-contrib-loadbalance": "latest",
"node-red-contrib-message-queue": "latest",
"node-red-contrib-mongodb4-dynamic": "latest",
"node-red-contrib-msg-router": "latest",
"node-red-contrib-prib-functions": "latest",
"node-red-contrib-routing": "latest",
"node-red-contrib-simple-message-queue": "latest",
"node-red-contrib-storage-mongodb": "latest",
"node-red-contrib-telegrambot": "latest",
"node-red-contrib-timeout": "latest",
"node-red-debugger": "latest",
"node-red-node-data-generator": "latest",
"redis": "latest",
"when": "latest"
"scripts": {
"start": "node index.js"
index.js:
var http = require('http');
var express = require('express');
var RED = require('node-red');
//env
//console.log(process.env);
var PASS = process.env.PASS2;
var host = process.env.DBHOST || 's8ptv';
var mongouri = process.env.DBURL || 'mongodb+srv://' + process.env.DBUSER + ':' + process.env.DBPASS + '@cluster0.' + host + '.mongodb.net/nrServer';
var appname = process.env.NRNS + '_' + process.env.APPID || 'default_node';
console.log(mongouri + ' | ' + appname);
// Create an Express app
var app = express();
// Add a simple route for static content served from 'public'
app.use('/', express.static('public'));
// Create a server
var server = http.createServer(app);
// Create the settings object - see default settings.js file for other options
var settings = {
exportGlobalContextKeys: true,
httpAdminRoot: '/admin',
httpNodeRoot: '/',
userDir: '/var/task',
functionGlobalContext: {},
adminAuth: {
type: 'credentials',
users: [
username: 'demo',
password: PASS,
permissions: '*',
// enables global context
externalModules: {
autoInstall: true /** Whether the runtime will attempt to automatically install missing modules */,
autoInstallRetry: 30 /** Interval, in seconds, between reinstall attempts */,
palette: {
/** Configuration for the Palette Manager */
allowInstall: true /** Enable the Palette Manager in the editor */,
allowUpload: true /** Allow module tgz files to be uploaded and installed */,
allowList: ['*'],
denyList: [],
modules: {
/** Configuration for node-specified modules */ allowInstall: true,
allowList: ['*'],
denyList: [],
editorTheme: {
/** The following property can be used to set a custom theme for the editor.
* See https://github.com/node-red-contrib-themes/theme-collection for
* a collection of themes to chose from.
//theme: "",
palette: {
/** The following property can be used to order the categories in the editor
* palette. If a node's category is not in the list, the category will get
* added to the end of the palette.
* If not set, the following default order is used:
//categories: ['subflows', 'common', 'function', 'network', 'sequence', 'parser', 'storage'],
projects: {
/** To enable the Projects feature, set this value to true */
enabled: false,
workflow: {
/** Set the default projects workflow mode.
* - manual - you must manually commit changes
* - auto - changes are automatically committed
* This can be overridden per-user from the 'Git config'
* section of 'User Settings' within the editor
mode: 'manual',
codeEditor: {
/** Select the text editor component used by the editor.
* Defaults to "ace", but can be set to "ace" or "monaco"
lib: 'monaco',
options: {
/** The follow options only apply if the editor is set to "monaco"
* theme - must match the file name of a theme in
* packages/node_modules/@node-red/editor-client/src/vendor/monaco/dist/theme
* e.g. "tomorrow-night", "upstream-sunburst", "github", "my-theme"
theme: 'hc-black',
/** other overrides can be set e.g. fontSize, fontFamily, fontLigatures etc.
* for the full list, see https://microsoft.github.io/monaco-editor/api/interfaces/monaco.editor.istandaloneeditorconstructionoptions.html
//fontSize: 14,
//fontFamily: "Cascadia Code, Fira Code, Consolas, 'Courier New', monospace",
//fontLigatures: true,
functionExternalModules: true,
storageModule: require('node-red-contrib-storage-mongodb'), //node-red-contrib-storage-mongodb
mongodbSettings: {
//mongoURI: "mongodb://mongodb/nodered",
//mongoURI: "mongodb+srv://user:pass@cluster0.cqm6vi1.mongodb.net/nodered",
//mongodb+srv://user:<password>@cluster0.s8ptv.mongodb.net/?retryWrites=true&w=majority
//host: cqm6vi1, s8ptv
mongoURI: mongouri,
appname: appname,
// Initialise the runtime with a server and settings
RED.init(server, settings);
// Serve the editor UI from /red
app.use(settings.httpAdminRoot, RED.httpAdmin);
// Serve the http nodes UI from /api
app.use(settings.httpNodeRoot, RED.httpNode);
console.log("open port");
server.listen(3000);
// Start the runtime
RED.start();
