HELP! Node is installed and npm/Node-RED cannot uninstall it
What is funny is that the node actually works fine... but I cannot upgrade it correctly to have the new updates work.
i probably installed this with npm in the wrong folder context... However, I'd like to see if I can get someone with knowledge about what I did wrong and how to go about un-doing it.
I have this folder here and it's apparently wrong. I used npm to install using the context.
"C:\Users\my_account\.node-red> npm uninstall .... but it fails.
Node-RED shows that I can upgrade it, but cannot remove it. I found the folder here.
"C:\Users\my_account\AppData\Roaming\npm\node_modules\node-red-contrib-opcua".
vs. where everything else is...
"C:\Users\my_account\.node-red\node_modules\node-red-contrib-_nodes_that_I_can_uninstall"
The question is which folder do I use in the command line context to uninstall it? I'm hoping that I can uninstall it and I just installed it in the wrong context.
Is the context ""C:\Users\my_account\AppData\Roaming\npm> npm uninstall... "
Thanks in advance!!
Post the output when you try to uninstall.
It looks like you installed it globally - so try uninstalling it with the -g opton... or you may also need to do that as an admin user. And then once done re-install to the correct place as your normal user.
