When I tried to uninstall a node, I got errors like this
$ npm uninstall my_proj
npm WARN checkPermissions Missing write access to /Users/me/.node-red/node_modules/my_proj
npm ERR! code ENOENT
npm ERR! syscall access
npm ERR! path /Users/me/.node-red/node_modules/my_proj
npm ERR! errno -2
npm ERR! enoent ENOENT: no such file or directory, access '/Users/me/.node-red/node_modules/my_proj'
npm ERR! enoent This is related to npm not being able to find a file.
npm ERR! enoent
npm ERR! /Users/me/.npm/_logs/2021-10-08T02_02_09_670Z-debug.log
The complete debug log looks like this
0 info it worked if it ends with ok
1 verbose cli [
1 verbose cli '/usr/local/Cellar/node@14/14.17.6/bin/node',
1 verbose cli '/usr/local/opt/node@14/bin/npm',
1 verbose cli 'uninstall',
1 verbose cli 'my_proj'
1 verbose cli ]
2 info using npm@6.14.15
3 info using node@v14.17.6
4 verbose npm-session 15b827f66a6db334
5 silly install loadCurrentTree
6 silly install readLocalPackageData
7 timing stage:loadCurrentTree Completed in 265ms
8 silly install loadIdealTree
9 silly install cloneCurrentTreeToIdealTree
10 timing stage:loadIdealTree:cloneCurrentTree Completed in 2ms
11 silly install loadShrinkwrap
12 timing stage:loadIdealTree:loadShrinkwrap Completed in 143ms
13 silly uninstall loadAllDepsIntoIdealTree
14 silly install loadAllDepsIntoIdealTree
15 timing stage:loadIdealTree:loadAllDepsIntoIdealTree Completed in 111ms
16 timing stage:loadIdealTree Completed in 291ms
17 silly currentTree node-red-project@0.0.1
17 silly currentTree ├── @protobufjs/aspromise@1.1.2
17 silly currentTree ├── @protobufjs/base64@1.1.2
17 silly currentTree ├── @protobufjs/codegen@2.0.4
23 silly saveTree │ │ ├── @protobufjs/utf8@1.1.0
23 silly saveTree │ │ ├── @types/long@4.0.1
23 silly saveTree │ │ └── long@4.0.0
23 silly saveTree │ ├─┬ alert@5.0.10
23 silly saveTree │ │ └── is-program-installed@2.2.0
23 silly saveTree │ ├── async@1.5.2
23 silly saveTree │ ├── google-protobuf@3.17.3
23 silly saveTree │ ├── lodash@4.17.21
23 silly saveTree │ └── minimist@1.2.5
23 silly saveTree ├── my_other_proj@1.0.0
23 silly saveTree └─┬ select_wobj_by_id@1.0.0
23 silly saveTree └─┬ alert@5.0.10
23 silly saveTree └── is-program-installed@2.2.0
24 verbose stack Error: ENOENT: no such file or directory, access '/Users/me/.node-red/node_modules/my_proj'
25 verbose cwd /Users/me/.node-red
26 verbose Darwin 20.6.0
27 verbose argv "/usr/local/Cellar/node@14/14.17.6/bin/node" "/usr/local/opt/node@14/bin/npm" "uninstall" "my_proj"
28 verbose node v14.17.6
29 verbose npm v6.14.15
30 error code ENOENT
31 error syscall access
32 error path /Users/me/.node-red/node_modules/my_proj
33 error errno -2
34 error enoent ENOENT: no such file or directory, access '/Users/me/.node-red/node_modules/my_proj'
35 error enoent This is related to npm not being able to find a file.
36 verbose exit [ -2, true ]
While it says no such file or directory, I do have it on the file system.
$ stat /Users/me/.node-red/node_modules/my_proj
16777221 21351017 lrwxr-xr-x 1 me myoffice\Domain Users 0 68 "Sep 28 16:16:33 2021" "Sep 28 16:16:33 2021" "Sep 28 16:16:33 2021" "Sep 28 16:16:33 2021" 4096 0 0 /Users/me/.node-red/node_modules/my_proj
The only workaround I found was to manually delete that symlink /Users/me/.node-red/node_modules/my_proj. Then uninstall works
audited 202 packages in 2.01s
5 packages are looking for funding
run `npm fund` for details
found 5 high severity vulnerabilities
run `npm audit fix` to fix them, or `npm audit` for details
What am I missing?
