Help with a trigger node - trick
I'm trying to optimise some code but am stuck.
This is my trigger node.
[{"id":"21982222.97dd2e","type":"trigger","z":"fb549e2f.4d026","g":"9f73c6fa33db761f","name":"","op1":"{\"command\": \"remove-all\"}","op2":"{\"command\":\"add\",\"name\":\"30\",\"payload\":\"30\",\"expression\":\"0 */30 * * * * *\"}","op1type":"json","op2type":"json","duration":"250","extend":false,"units":"ms","reset":"","bytopic":"all","outputs":1,"x":1330,"y":1800,"wires":[["15e1c4e1.b0dbab"]]}]
This part in particular:
{"command":"add","name":"30","payload":"30","expression":"0 */30 * * * * *"}
The 30 part is variable.
It could be 5, 10, 12, 15, 20, 30, or 60.
So the event is done at those frequencies.
How can I make this value set by msg.payload, either in that node or I could construct the message in a function node and have that sent into the trigger node.
How about this? I don't now exacly what you want to do :wink:
Looks like adding stuff to the the cron-plus node?
[{"id":"59a30ad669ffa86c","type":"inject","z":"8c6cb615b3919618","name":"30","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"30","payloadType":"num","x":270,"y":220,"wires":[["21982222.97dd2e"]]},{"id":"6b6fb16ecfc05e98","type":"function","z":"8c6cb615b3919618","name":"format","func":"const p = msg.payload\nmsg.payload = {\n    \"command\":\"add\",\n    \"name\":`${p}`,\n    \"payload\":`${p}`,\n    \"expression\":`0 */${p} * * * * *`\n}\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":830,"y":160,"wires":[["cac826c266164a5a"]]},{"id":"cac826c266164a5a","type":"debug","z":"8c6cb615b3919618","name":"dynamic","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1000,"y":220,"wires":[]},{"id":"b3d0d145cd6d3ed8","type":"inject","z":"8c6cb615b3919618","name":"15","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"15","payloadType":"num","x":270,"y":180,"wires":[["21982222.97dd2e"]]},{"id":"21982222.97dd2e","type":"trigger","z":"8c6cb615b3919618","name":"","op1":"{\"command\": \"remove-all\"}","op2":"","op1type":"json","op2type":"pay","duration":"250","extend":false,"overrideDelay":false,"units":"ms","reset":"","bytopic":"all","topic":"topic","outputs":1,"x":480,"y":220,"wires":[["441d9406a868e29c"]]},{"id":"441d9406a868e29c","type":"switch","z":"8c6cb615b3919618","name":"Number?","property":"payload","propertyType":"msg","rules":[{"t":"istype","v":"number","vt":"number"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":660,"y":220,"wires":[["6b6fb16ecfc05e98"],["cac826c266164a5a"]]}]
Nice, but not quite.
The second command needs to be a bit more.... complicated.
Your gives me nearly enough, but not quite enough.
Sorry I didn't mention it originally, but the message is being sent into the cron-plus node.
I need to add a schedule that repeats every.... 5, 6, 10, 12, 15.... etc minutes.
So it needs to be
where the 30 is the message received and the entire line is what is sent.
Thanks.
Ooops.
Sorry.
I think that does work.
Hang on.
Adding multiple schedules to the cron-plus node at the given intervalls:
[{"id":"4a9ce1991df50e32","type":"inject","z":"8c6cb615b3919618","name":"intervalls","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"[5,10,12,15,20,30,60]","payloadType":"json","x":260,"y":480,"wires":[["4743b5ef1816d934","5592076892aa31a6"]]},{"id":"4743b5ef1816d934","type":"split","z":"8c6cb615b3919618","name":"","splt":"\\n","spltType":"str","arraySplt":1,"arraySpltType":"len","stream":false,"addname":"","property":"payload","x":430,"y":480,"wires":[["7f375f758287737b"]]},{"id":"7f375f758287737b","type":"function","z":"8c6cb615b3919618","name":"format","func":"const p = msg.payload\nmsg.payload = {\n    \"command\":\"add\",\n    \"name\":`${p}`,\n    \"payload\":`${p}`,\n    \"expression\":`0 */${p} * * * * *`\n}\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":570,"y":480,"wires":[["06e1b527fb0597a4"]]},{"id":"06e1b527fb0597a4","type":"join","z":"8c6cb615b3919618","name":"","mode":"auto","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","useparts":false,"accumulate":"false","timeout":"","count":"","reduceRight":false,"x":730,"y":480,"wires":[["6a1e7a11f7b55f8c","cec843e969361d1d"]]},{"id":"6a1e7a11f7b55f8c","type":"debug","z":"8c6cb615b3919618","name":"dynamic","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":880,"y":480,"wires":[]},{"id":"cec843e969361d1d","type":"cronplus","z":"8c6cb615b3919618","name":"","outputField":"payload","timeZone":"","storeName":"","commandResponseMsgOutput":"output1","defaultLocation":"","defaultLocationType":"default","outputs":1,"options":[],"x":880,"y":540,"wires":[[]]},{"id":"5592076892aa31a6","type":"change","z":"8c6cb615b3919618","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"{\"command\": \"remove-all\"}","tot":"json"}],"action":"","property":"","from":"","to":"","reg":false,"x":460,"y":540,"wires":[["cec843e969361d1d"]]}]
GREATEST APOLOGIES
It did work.
Only 1 schedule needs to be active.
That's why I send the WIPE command first.
I goofed when putting your code in my test flow and hadn't realised a mistake with it and the problem is my end.
It does work.
Thanks.
(That is the first one you posted.)
