Help with controlling relay board by using node-RED
hello. I'm looking for help with this error:
Welcome to the Node-RED Dashboard
Please add some UI nodes to your flow and redeploy
I have noticed a common problem with this....
28 Dec 22:19:48 - [info] Node-RED version: v2.1.4
28 Dec 22:19:48 - [info] Node.js version: v14.18.2
28 Dec 22:19:48 - [info] Linux 5.10.63-v7l+ arm LE
28 Dec 22:19:49 - [info] Loading palette nodes
28 Dec 22:19:52 - [info] Dashboard version 3.1.2 started at /ui
28 Dec 22:19:52 - [info] Settings file : /home/pi/.node-red/settings.js
28 Dec 22:19:52 - [info] Context store : 'default' [module=memory]
28 Dec 22:19:52 - [info] User directory : /home/pi/.node-red
28 Dec 22:19:52 - [warn] Projects disabled : editorTheme.projects.enabled=false
28 Dec 22:19:52 - [info] Flows file : /home/pi/.node-red/flows.json
What error?
I'm not seeing any error messages.
What is causing you concern?
Dashboard ui not working
Have you added any dashboard nodes, such as a button or switch?
If not, there will be nothing to display.
not. only inject and rpi-gpio out node..
Well that's why your dashboard isn't working.
Try adding some.
The photos are not helping!
You need to add one or more nodes from the dashboard set of nodes, otherwise there is nothing to display.
Also read the dashboard instructions.
dash
can you teach me to do it?
I apologize if I speak incomprehensibly...i want to learn to work with raspbery.. :slight_smile:
thanks for trying to help
You must describe in much more detail, what you are trying to achieve, and what is not working.
Otherwise it's difficult to help you.
my purpose is these relays. I want to manage them remotely
RPi Relay Board (B) - Waveshare Wiki
Well the topic title is currently ERROR: Welcome to the Node-RED Dashboard Please add some UI nodes to your flow and redeploy which does not describe your problem.
I'll change it to something more suitable and then someone will hopefully be able to help you
i added a switch and everything works. Thank you very much
