Help with how to better construct this message using GLOBAL context
Ok: me being anal, or not. :person_shrugging:
I have this in an exec node:
tail -n11 /media/pi/9020-9C27/events/commands_received.txt | cat
Which is fair enough.
But I also have this in global context:
event_paths as /media/pi/9020-9C27/events/ and
log_paths as /media/pi/9020-9C27/logs/ (Ok not needed here, but....)
So I am wanting to translate the event_paths into the command.
(As best I can explain it showing the structure)
tail -n11 *globalContext_even_paths*commands_received.txt | cat
The nodes:
[{"id":"74647831.e6bf18","type":"inject","z":"a3bd09a.b852978","name":"","repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":310,"y":210,"wires":[["88ec09d0.6e1c28"]]},{"id":"88ec09d0.6e1c28","type":"exec","z":"a3bd09a.b852978","command":"ls -1 --file-type /media/pi/9020-9C27/logs/reboot/ | grep -v '/' | sed s/@$// | cat","addpay":false,"append":"","useSpawn":"false","timer":"","oldrc":false,"name":"Cat","x":470,"y":210,"wires":[["17917965.d43657","87a8c9d9.4f7f58"],[],[]]}]
Any ideas please?
Why not construct your command line in a function or template node and pass the whole lot to exec as msg.payload, leaving Command in the exec node blank?
Incidentally, I'm pretty sure that your trailing | cat does nothing useful, though it does no harm either.
I guess that would be the simple way.
Thanks.
I seem to have this ability to make simple things difficult for myself more times than I should.
I'll give it a go.
Or
[{"id":"88ec09d0.6e1c28","type":"exec","z":"53a4dcf62732d6d9","command":"","addpay":"payload","append":"","useSpawn":"false","timer":"","winHide":false,"oldrc":false,"name":"Cat","x":1000,"y":1260,"wires":[["e3a8afb54bab0451"],["e3a8afb54bab0451"],["e3a8afb54bab0451"]],"info":"\"ls -1 --file-type \" & $globalContext(reboot) & \" | grep -v '/' | sed s/@$// | cat\""},{"id":"f0ea16b4c993cc86","type":"inject","z":"53a4dcf62732d6d9","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"\"ls -1 --file-type \" & $globalContext(\"reboot\") & \" | grep -v '/' | sed s/@$// | cat\"\t","payloadType":"jsonata","x":830,"y":1260,"wires":[["88ec09d0.6e1c28"]],"info":"\"ls -1 --file-type \" & $globalContext(reboot) & \" | grep -v '/' | sed s/@$// | cat\"\r\n\"tail -n11 \" & $globalContext(\"event_paths\") & \"commands_received.txt | cat\""}]
(Mind blown.)
But it is (at this point in time) MAGIC.
The command
"ls -1 --file-type " & $globalContext("reboot") & " | grep -v '/' | sed s/@$// | cat"
is way beyond my skill set. (Not your problem)
But I can't draw a comparison to the original command:
ls vs tail They are two very different commands.
I'll run off and do some digging and see what I learn.
But thanks.
IGNORE THIS REPLY
Sorry, I goofed.
Left in because I'm dumb.
Ok, sorry I didn't declare this at the start.
The command is being used in a watch node.
Monitoring file activity in the given directory.
Alas the watch node (both file and directory) doesn't have an input.
In your original post you talked about
which as you know prints the last 11 lines in the file.
But in your sample flow the exec node is set to run
which lists the files in the reboot directory, ignoring subdirectories and stripping any @ symbols off the end of the filename.
So they are indeed very different commands. :grinning_face_with_smiling_eyes:
Which one are you trying to parameterise with the global context variable?
Maybe you should share a bit more of the flow (not all of it please!)
You are right.
I got confused. So many things happening.
Ignoring my incorrect post (number 5)....
I am wanting to display the last few lines of the reboot log file.
The rub (for me) is that I am entering the entire path - which is fixed.
Small part of the code:
[{"id":"74647831.e6bf18","type":"inject","z":"a3bd09a.b852978","name":"","repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":310,"y":210,"wires":[["88ec09d0.6e1c28"]]},{"id":"88ec09d0.6e1c28","type":"exec","z":"a3bd09a.b852978","command":"ls -1 --file-type /media/pi/9020-9C27/logs/reboot/ | grep -v '/' | sed s/@$// | cat","addpay":false,"append":"","useSpawn":"false","timer":"","oldrc":false,"name":"Cat","x":470,"y":210,"wires":[["17917965.d43657","87a8c9d9.4f7f58"],[],[]]},{"id":"17917965.d43657","type":"split","z":"a3bd09a.b852978","name":"","splt":"\\n","spltType":"str","arraySplt":1,"arraySpltType":"len","stream":false,"addname":"","x":670,"y":200,"wires":[["f8e85ffb.27a12","a2f4ed08.9b76d"]]},{"id":"f8e85ffb.27a12","type":"switch","z":"a3bd09a.b852978","name":"","property":"payload","propertyType":"msg","rules":[{"t":"nempty"}],"checkall":"true","repair":false,"outputs":1,"x":670,"y":250,"wires":[["8d28b379.4fc7b","4df38dde.8dd85c"]]},{"id":"4df38dde.8dd85c","type":"debug","z":"a3bd09a.b852978","name":"3","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":840,"y":250,"wires":[]}]
The switch node may not be needed. It is included .... yeah. I'm not sure.
But as it, it works.
I think it is to handle the case if the file is empty. But I 'm not sure it is the right way of doing it.
So....
The problem is that if ever I change the USB stick to another one.
I just edit the global context and don't need to also edit this node. (And others like it)
Probably as suggested in reply 2 I do it that way.
Ok, expansion on things.
Here is another (sorry) bit of the code.
[{"id":"74647831.e6bf18","type":"inject","z":"a3bd09a.b852978","name":"","repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":310,"y":210,"wires":[["88ec09d0.6e1c28"]]},{"id":"88ec09d0.6e1c28","type":"exec","z":"a3bd09a.b852978","command":"ls -1 --file-type /media/pi/9020-9C27/logs/reboot/ | grep -v '/' | sed s/@$// | cat","addpay":false,"append":"","useSpawn":"false","timer":"","oldrc":false,"name":"Cat","x":470,"y":210,"wires":[["17917965.d43657","87a8c9d9.4f7f58"],[],[]]},{"id":"17917965.d43657","type":"split","z":"a3bd09a.b852978","name":"","splt":"\\n","spltType":"str","arraySplt":1,"arraySpltType":"len","stream":false,"addname":"","x":670,"y":200,"wires":[["f8e85ffb.27a12","a2f4ed08.9b76d"]]},{"id":"a2f4ed08.9b76d","type":"debug","z":"a3bd09a.b852978","name":"2","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":840,"y":200,"wires":[]},{"id":"f416f19bd14acba1","type":"inject","z":"a3bd09a.b852978","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":1010,"y":140,"wires":[["3b8e8db1663c4cfe"]]},{"id":"3b8e8db1663c4cfe","type":"change","z":"a3bd09a.b852978","name":"command","rules":[{"t":"set","p":"payload","pt":"msg","to":"\"ls -1 --file-type \" & $globalContext(\"reboot\") & \" | grep -v '/' | sed s/@$// | cat\"\t","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":1180,"y":140,"wires":[["f84266302b2910d0"]]},{"id":"f84266302b2910d0","type":"exec","z":"a3bd09a.b852978","command":"","addpay":"payload","append":"","useSpawn":"false","timer":"","winHide":false,"oldrc":false,"name":"","x":1400,"y":140,"wires":[["17917965.d43657"],[],[]]}]
Desired.
What the new code gives me.
I'll see if I can work out where the problem is.
I'm guessing it is getting a list of all files rather than the one I want.
AH!
Removing the wire between the change and the exec node (on the right) and replacing it with a debug I get this strange output:
But the original command in theoriginal exec node is this command:
Slight difference.
Confused.
Ah2!
Is this this what should be in the change node?
"ls -1 --file-type " & $globalContext("log_path") & "reboot | grep -v '/' | sed s/@$// | cat"
That seems to be giving me the expected result.
RESOLVED!
Thanks folks.
