I think I got it working. Or at least: It seems to be.
Before the node I put a change node and set msg.now as timestamp.
Out of the node I have this:
Example.
[{"id":"5cdd808a.0d6db8","type":"switch","z":"10fde8b5.a8a82f","name":"","property":"now","propertyType":"msg","rules":[{"t":"lt","v":"payload.sunrise","vt":"msg"},{"t":"gt","v":"payload.sunset","vt":"msg"},{"t":"else"}],"checkall":"true","repair":false,"outputs":3,"x":1420,"y":750,"wires":[["c125972d.f52058"],["c125972d.f52058"],["8eb3fc7c.41e288"]]},{"id":"c125972d.f52058","type":"change","z":"10fde8b5.a8a82f","name":"Darksky cloudy (night)","rules":[{"t":"set","p":"payload","pt":"msg","to":"<i class=\"wi-darksky-partly-cloudy-night\"></i>","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1620,"y":730,"wires":[[]]},{"id":"8eb3fc7c.41e288","type":"change","z":"10fde8b5.a8a82f","name":"Darksky cloudy","rules":[{"t":"set","p":"payload","pt":"msg","to":"<i class=\"wi wi-darksky-cloudy\"></i>","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1600,"y":770,"wires":[[]]}]
The switch node is repeated for all the different types of output so I have a day and night icon used.
Thanks to all who participated.
Sorry folks. As I have said many time: I sometimes need to discuss it with others so I can see things better.
That's not to say the help wasn't useful. It showed me a couple of mistakes I always seem to make.
So, now all is good for now.
(I can paste a bigger version of the code if you want.)
Or a screen shot.
