on new node red, it's possible to hide/show node labels. But when you drag and drop a node to flow, on default the label is shown. How can I hide label on drag and drop (same as link node) ?
If a node label is hide, they save it as property l: { value: false}.
I use this on "defaults" section. But it works not correct every time.
What is the solution ?
