I am trying to create a simple HMI (human machine interface) to turn a LED on/off using node-red on openPLC ( openPLC is installed on Raspberry PI) . I am new to this entire PLC and not able to get any tutorial as to how to build a HMI using node-red. any help is appreciated.
take a look at node-red-dashboard which is the simplest way
This is not related to the above conversation.
Can we install node-red in PC1 and connect to an openPLC which is installed on raspberry PI with IP and send messages using MODBUS TCP/IP protocol ?
If it is NOT related to the above question please open a new thread
yeah that's perfectly doable.
Can you please help me out here. I went through the link https://flows.nodered.org/?term=modbus&num_pages=1 to check for configuring openPLC node and other input nodes but dint find anything useful.
Try googling “node-red openplc”
Thanks. will look into it.
i too looking for same poc for this which is similar to yours on subject : how to integrate raspberry pi zero with openplc and along with HMI as node red over modbus tcp protocol
