How can I change the color of a button without changing the output?
I'm trying to implement a webradio with a Raspberry Pi, node-red and MPC, that can be controlled with a LIRC IR window control.
The station selection should indicate the current station in color.
I have found an example with led display.
[https://flows.nodered.org/flow/a7f16a3f276ac5cb51e5c760572afd8e]
My modification changes the color of the button, but the station changes shortly and then only station 1 is played.
flows(1).json (17.3 KB)
I was looking for an example here where buttos change color without changing the output. None of them I understood for my application.
It would be nice if someone could help me.
I don't know if you have seen this topic, but it would seem to provide a good starting point for your problem.
If you have older dashboard, this may be labelled differently (like pass through msg)
Only in station 1 I find:
node-red-click
after removal my little internet radio runs perfectly.
Thanks for the help
Thomas
