How read array?
Hi to all! I apologize but I am still newbie about nred...
I need to display data on map, so I started reading data from sqlite table.
I can correctly query my table using function but output is:
array[38]
0: object
 lat: "12.433"
 lon: "12.444"
1: object....
I don't understand how read all array elements and send data to map, how can I create output msg for every element?
Thanks.
If you send it through a Split node it will split it into 38 messages, each containing one element from the array.
Ok, thanks, I supposed to work with Split node but I thought it was wrong due I read "separator" field...
actually node-red-contrib-web-worldmap would probably take that array as-is and display all the points :slight_smile:
