How to add new sensor in node-red
Hi, I am a newbie here. I have worked with node-red that has already installed sensors or I got npm install files from the internet.
But now I want to work with this temp and hum sensor and send its data to google sheet using node-red.
But, how can I add this sensor in node-red?
Any leads will be a great help.
Thanx in advance.
How do you read the data coming from the sensor ?
Its an I2c device so you could use https://flows.nodered.org/node/node-red-contrib-i2c to get data from it.
Unfortunately, this is going to require a bit of prodding and poking to get it working
This should give an idea of commands needed and format of received messages
PS You can proably get the module in a cheaper configuration
https://www.ebay.co.uk/sch/i.html?_from=R40&_trksid=m570.l1313&_nkw=sht31&_sacat=0
Hi Adam, I’m a bit late to the conversation. Have you followed NCD’s own Node-RED tutorial for connecting these sensors to Node-RED yet? For connecting it to a google spreadsheet there’s countless of questions on this forum, a search should find you a solution that works. But start with NCD’s tutorial, it gives you the basics.
I just published a first version of a node for the SHT31...
SHT31 Contrib Module
it's barely tested, but it works for my custom setup... any feedback welcome...
