Hellow guys, I want to change the color of the text to white, but i can't find a way to do it, i've tried with CSS but I don't know if I'm doing something wrong, I would be very grateful if you help me
Ummm, if you change the text color to white, you won't be able to see it on the white background. Be that as it may, can you show us what you have tried?
Thank you very much @zenofmud for replying, you´re right if I change it to white, I won´t be able to see anything, but I was thinking about changing that background to a darker color, after hours of trying I was able to do it, I just had to point to the right panth using CSS, I've done it like this. Thank you very much for your time
Look in the side bar (right hand side) next to the debug pane there is a pane named dashboard where you can set the theme and colours.
Ohhhhh, thank you very muchhh @Steve-Mcl I didn't know about that option
