Hello, I need to connect Mapbox satellite map to worldmap node.
I know that MapBox3D is one of the base maps, so I'm assuming satellite map also can be connected, but I didn't find anything in the documentation
Do you have a pointer to that map server ? The docs do show how to add new base layers - GitHub - dceejay/RedMap: A web map app for Node-RED to put blobs on
Yeah, thank you, that was my mistake I didn't check github page.
This is how I solved the problem - video that shows how to get tile vector url ( put that url into map url field in worldmap node) Using Mapbox styles in Leaflet - YouTube
And I put this into map options field:
{ "attribution": "Map data © <a href="https://www.openstreetmap.org/\">OpenStreetMap contributors, <a href="https://creativecommons.org/licenses/by-sa/2.0/\">CC-BY-SA, Imagery © <a href="https://www.mapbox.com/\">Mapbox</a>", "maxZoom": 22 }
(more info in javascript - Use a custom created Mapbox style (from Mapbox Studio) along with Leaflet - Stack Overflow)
I hope this will be helpful to others
