How to convert a string
I have a Novus device which has RS-485 communication and works as a modbus gateway.
It is possible to read/write to slave devices connected to the gateway over MQTT publish.
The device return in another topic a payload containing the modbus response in HEX, but the result comes as a string.
string 2
What I want is the value on the requested register.
string result
I've tried to follow some tutorials on how to parse modbus values, but lead me to nowhere.
how can I convert this string to the real value of the register?
Sorry if this is a repeated topic, But I didn't find anything related to this.
I would appreciate any help.
Thanks.
Hello .. you can try in a Function node
// remove spaces from string
let buf = msg.payload.replaceAll(" ", "");
node.warn(buf)
// convert string to Buffer
buf = Buffer.from(buf, "hex")
// read Int from offset
msg.payload = buf.readInt16BE(3);
Example flow :
[{"id":"8b3e824f6868e38a","type":"inject","z":"937cb040.d8e16","name":"hex string","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"03 03 04 01 2D 00 00 48 06","payloadType":"str","x":380,"y":640,"wires":[["38c5be1a1f276787"]]},{"id":"38c5be1a1f276787","type":"function","z":"937cb040.d8e16","name":"function","func":"// remove spaces from string\nlet buf = msg.payload.replaceAll(\" \", \"\");\nnode.warn(buf)\n\n// convert string to Buffer\nbuf = Buffer.from(buf, \"hex\")\n\n// read Int from offset \nmsg.payload = buf.readInt16BE(3);\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":560,"y":640,"wires":[["6ef999e4341e5a25"]]},{"id":"6ef999e4341e5a25","type":"debug","z":"937cb040.d8e16","name":"debug 26","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":740,"y":640,"wires":[]}]
Hey @UnborN, you helped me so much.
Your solution worked.
I was able to combine your function with another piece of code that I had.
Now I can have both address and value on the payload.
debug payload
I know that is probably an ugly workaround, but works for me at the moment.. :slight_smile:
Thank you, man.
You rock!
