How to delete the custom node from sidebar
How to delete the custom node from sidebar?
I couldnt rename it so I made the new node with same functionallity but with different name.
How did you install the custom node in the first place?
npm install and then the path to folder in .node-red folder
As node-red-contrib-example-...
Then you can do npm remove <name-of-module> in the same .node-red directory. Then restart Node-RED.
Thank you.
