In dashboard I'm having two world map(in separate tabs) in two flows, I have configured the inject node to inject message once it loads. But once it injects it injects to wrong world map. So, how can correct this one.
Each one should have a different endpoint path to be unique.
You mean Web Path property I should change for each as default will be /worldmap
Yes that's correct
