I'm reading in status of a device over modbus. That part works. So when I put my device into ready mode(not from the dash), my dash shows ready. But now I want to use the dash to put my device into ready mode. I understand that there may be some conflict of status. How is the flow supposed to look if I want to do this?
Right now I have this:
I'm reading a status from modbus, processing it and turning on an indicator.
But now instead of an indicator, I'd like it to be a slider switch on the dash to indicate the status. At the same time, I can toggle the switch on the dash to change the status of the device.
How do I do this?
[{"id":"5b452c81.cb87b4","type":"tab","label":"Flow 1","disabled":false,"info":""},{"id":"bc532f5a.76fa1","type":"modbus-read","z":"5b452c81.cb87b4","name":"device","topic":"device","showStatusActivities":false,"logIOActivities":false,"showErrors":false,"unitid":"0","dataType":"Coil","adr":"0","quantity":"8","rate":"1","rateUnit":"s","delayOnStart":false,"startDelayTime":"","server":"bf81420f.323c4","useIOFile":false,"ioFile":"","useIOForPayload":false,"emptyMsgOnFail":false,"x":130,"y":360,"wires":[["9b608007.5066"],[]]},{"id":"9b608007.5066","type":"function","z":"5b452c81.cb87b4","name":"","func":"var x = [0,0,0,0,0,0,0,0];\nvar msg_o = [msg,msg,msg,msg,msg,msg,msg,msg]\n\nfor(i = 0; i <8; i++){\n x[i] = msg.payload[i];\n if(x[i] == true){\n msg_o[i] = {payload:true}\n } else{\n msg_o[i] = { payload:false};\n }\n}\n\n\nreturn msg_o;","outputs":8,"noerr":0,"initialize":"","finalize":"","x":340,"y":360,"wires":[[],["482dbfc8.8dcf"],[],[],[],[],[],[]]},{"id":"6d1d5f9.45a46a","type":"change","z":"5b452c81.cb87b4","name":"","rules":[{"t":"set","p":"message","pt":"msg","to":"Run","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":670,"y":320,"wires":[["e066460a.da2f58","536a9d0d.c88af4"]]},{"id":"ad16c194.f3522","type":"change","z":"5b452c81.cb87b4","name":"","rules":[{"t":"set","p":"message","pt":"msg","to":"Standby","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":670,"y":360,"wires":[["e066460a.da2f58","536a9d0d.c88af4"]]},{"id":"482dbfc8.8dcf","type":"switch","z":"5b452c81.cb87b4","name":"","property":"payload","propertyType":"msg","rules":[{"t":"true"},{"t":"false"}],"checkall":"true","repair":false,"outputs":2,"x":490,"y":340,"wires":[["6d1d5f9.45a46a"],["ad16c194.f3522"]]},{"id":"e066460a.da2f58","type":"ui_led","z":"5b452c81.cb87b4","group":"f9407652.65bd68","order":6,"width":0,"height":0,"label":" {{msg.message}}","labelPlacement":"left","labelAlignment":"left","colorForValue":[{"color":"red","value":"false","valueType":"bool"},{"color":"green","value":"true","valueType":"bool"}],"allowColorForValueInMessage":false,"name":"Run/Standby","x":890,"y":340,"wires":[]},{"id":"6e7d658c.ff134c","type":"comment","z":"5b452c81.cb87b4","name":"Spray Status","info":"","x":670,"y":280,"wires":[]},{"id":"c4a5ee95.b86e1","type":"comment","z":"5b452c81.cb87b4","name":"run/standby","info":"","x":1050,"y":340,"wires":[]},{"id":"61848607.ed4038","type":"comment","z":"5b452c81.cb87b4","name":"Reading Boolean from device","info":"","x":140,"y":320,"wires":[]},{"id":"1722b3b9.a388dc","type":"comment","z":"5b452c81.cb87b4","name":"Bool Addressing conforms to that of the Click PLC.","info":"","x":250,"y":500,"wires":[]},{"id":"536a9d0d.c88af4","type":"debug","z":"5b452c81.cb87b4","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":890,"y":260,"wires":[]},{"id":"bf81420f.323c4","type":"modbus-client","name":"1750+ 2","clienttype":"tcp","bufferCommands":true,"stateLogEnabled":true,"queueLogEnabled":true,"tcpHost":"10.13.1.74","tcpPort":"502","tcpType":"DEFAULT","serialPort":"/dev/ttyUSB","serialType":"RTU-BUFFERD","serialBaudrate":"9600","serialDatabits":"8","serialStopbits":"1","serialParity":"none","serialConnectionDelay":"100","unit_id":1,"commandDelay":1,"clientTimeout":1000,"reconnectOnTimeout":true,"reconnectTimeout":2000,"parallelUnitIdsAllowed":true},{"id":"f9407652.65bd68","type":"ui_group","name":"1750+ 2","tab":"a1387b82.164db8","order":2,"disp":false,"width":"10","collapse":false},{"id":"a1387b82.164db8","type":"ui_tab","name":"Home","icon":"dashboard","order":1,"disabled":false,"hidden":false}]
