How to increase font size in function node editor (Victron Cerbo)
For changing config files in Venus OS I found the hint on Github:
Since the root filesystem is mounted read-only, you will need to remount it to read-write before you can edit the file. There are three ways to change that:
  • temporally: issue the command mount -o remount,rw / (which holds until the next reboot or issueing mount -o remount,ro /)
  • semi-permanent: issue the command /opt/victronenergy/swupdate-scripts/remount-rw.sh (which holds until the next firmware update)
Maybe it is relevant..?
Reposted below
That is because you are not posting as a code block...
In order to make code readable and usable it is necessary to surround your code with three backticks (also known as a left quote or backquote ```)
   code goes here
You can edit and correct your post by clicking the pencil :pencil: icon.
It locks up on selecting code quotes.
Reopened this page so many times now that I've inadvertantly edited this post !
Safari? Old version of Chrome? Internet Explorer?
You really dont include enough info in your posts to properly help you :frowning:
Also, you can simply type in the three backticks ``` using your keyboard (or even copy paste these backticks from my post)
Edit: It's opera
I didn't know you could just type the backticks...
Weird...just typed the backticks and it locked up again.
